Author Topic: N54 6MT Transmission Fluid Change  (Read 5975 times)
0 Members and 1 Guest are viewing this topic.
Offline Rob.K
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
  • Vehicle: 2008 135i 6MT
« on: April 17, 2014, 02:36:14 PM »
***Always safely support your vehicle before working underneath it***
I replaced the OEM Transmission Drain plug with a magnetic drain plug
Thanks to DanielZio for letting me use his AMSOIL Bottle Hand Pump!
Tools Needed:
-8mm Socket
-8mm Hex Bit
-Torque Wrench
-Car jack & jack stands and/or Ramps
-OEM or Magnetic Transmission Drain Plug
-2 Liters of MT Fluid - I used Redline MT90, changing gears feels buttery smooth now!
-Something to transfer the Transmission Fluid from its container to the Transmission -  I used a AMSOIL Bottle Hand Pump
-A pan to catch the draining fluid
-Shop Towels to clean up any spillage
1. Jack up the car safely or drive onto ramps
2. Remove splash shield using 8mm socket wrench. Once all 8mm screws are removed, turn the entire panel to clear the catch and remove.
3. Use 8mm Hex Bit to remove Filler Plug first! You don't want to drain the fluid out and then not be able to open the filler plug. Once filler plug is removed, place catch pan underneath drain plug and remove drain plug.
4. Once all fluid is drained, install drain plug and torque to spec - 35 Nm / 26 ft lbs
5. Use hand pump to fill transmission will fluid. Keep filling until fluid overflows out of filler hole. It should take about 1.6-1.8 L
6. Install Filler Plug and torque to spec - 35 Nm / 26 ft lbs
7. Install splash shield - and you're done. Simple as that  :)
Current - 2008 135i 6MT | JB4 | BMS DCI | CP-E FMIC | ER CP | Meth Addict | BMS DP's
Current - 2008 4.8i X5
Sold   -    2007 335xi AT | JB4 | BMS DCI | CP-E FMIC | ER CP | Meth Addict | AR DP's | Vanguard Exhaust | 12.1@117
Offline TDHartog
  • Trade Count: (0)
  • Newbie
  • Gender: Male
  • 1st gear
    • View Profile
  • Vehicle: LCI E90 335
Re: N54 6MT Transmission Fluid Change
« Reply #1 on: April 26, 2014, 10:12:12 AM »
Was there a significant change in the feel of your shifts?
Offline Rob.K
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
« Reply #2 on: April 26, 2014, 02:40:57 PM »
Actually yes! Quite a bit different, in a good way. Felt very notchy before and much smoother now. I'd recommend doing this but it would probably be a good idea to switch to a thinner fluid for winter time
Offline TDHartog
  • Trade Count: (0)
  • Newbie
  • Gender: Male
  • 1st gear
    • View Profile
« Reply #3 on: April 30, 2014, 09:07:41 AM »
My E90 is parked in the winter so it'll be ok  :P
Offline Rob.K
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
« Reply #4 on: April 30, 2014, 09:08:13 PM »
Hahah same with mine  :D
Offline e90nate
  • Trade Count: (0)
  • Newbie
  • Gender: Male
  • 1st gear
    • View Profile
  • Vehicle: E90 335i
« Reply #5 on: May 05, 2014, 02:42:59 PM »
rob would this diy also be a good starting point to change trans output shaft and shift rod seal?
Offline Rob.K
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
« Reply #6 on: May 07, 2014, 12:00:34 PM »
I haven't done any trans seals in a vehicle before but I would think that it would be substantially more work. I'll look into it for you though :)
Offline e90nate
  • Trade Count: (0)
  • Newbie
  • Gender: Male
  • 1st gear
    • View Profile
  • Vehicle: E90 335i
« Reply #7 on: May 08, 2014, 08:56:17 AM »
thanks man, my friends 335i 6 speed has a slow leak/sweating
