Hey guys, I have a weird electrical problem and need help figuring it out.
The radio buttons, steering wheel controls, dsc/lock buttons, headlight switch, and all window switches are not lighting up! All buttons do work however but i just cant see anything at night. When the headlight switch is at the 0 position it lights up fine, but as soon as i switch it to the drl or "headlights on" position, it doesnt light up and the above mentioned lights don't light up. Only things that light up when i switch on the headlights are the cluster, radio screen, heat controls, gear selector(P R N D) lights up faintly, and sunroof switch.
A week before this happened, I replaced the angel eyes bulbs to LED ones and got the drl disabled (coding). All fuses checked out fine, i put the stock bulbs in and disconnected the battery for 30 mins and still same problem. Only thing i remember doing prior to this problem was pulling out one of the door locks actuator fuse and replace it with a higher amp one.
Anyone encountered anything like this before?
