Author Topic: Have question?  (Read 4809 times)
0 Members and 1 Guest are viewing this topic.
Offline cal320i
  • Trade Count: (0)
  • Newbie
  • Gender: Male
  • 1st gear
    • View Profile
  • Vehicle: 320i, 2004
Have question?
« on: February 08, 2014, 06:28:25 PM »
Hi,
I'm new to this forum. I need advise. My question is, I own 2004 320i has 115 km and what should I do to maintain my car running good?
Offline Rob.K
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
  • Vehicle: 2008 135i 6MT
Re: Have question?
« Reply #1 on: February 08, 2014, 06:55:35 PM »
Good place to start would be
- oil and filter change every 8-10,000km
- brake fluid, coolant flush, trans fluid, rear differential fluid change every 2 years
- new spark plugs every 100,000km
- check brake pads and rotors every 15,000km
- hand wash and wax regularly
I attached a pdf of Mike Millers Old School BMW Maintenance Schedule, it's a good read  :)
Current - 2008 135i 6MT | JB4 | BMS DCI | CP-E FMIC | ER CP | Meth Addict | BMS DP's
Current - 2008 4.8i X5
Sold   -    2007 335xi AT | JB4 | BMS DCI | CP-E FMIC | ER CP | Meth Addict | AR DP's | Vanguard Exhaust | 12.1@117
Offline cal320i
  • Trade Count: (0)
  • Newbie
  • Gender: Male
  • 1st gear
    • View Profile
Re: Have question?
« Reply #2 on: February 08, 2014, 07:15:05 PM »
Thank you for good info. Do you've any idea, where I can buy real OEM parts in Calgary that can do some DIY's?
Offline Rob.K
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
Re: Have question?
« Reply #3 on: February 08, 2014, 07:24:48 PM »
Depends what type of parts you're looking for. But I would give NAPA a try. Or check out www.autopartsway.ca, www.rockauto.com, or www.ecstuning.com online.
If you need to find part numbers, www.realoem.com is the place to go.
Offline cal320i
  • Trade Count: (0)
  • Newbie
  • Gender: Male
  • 1st gear
    • View Profile
Re: Have question?
« Reply #4 on: February 08, 2014, 07:40:22 PM »
Did my VIN decor and find out this code S915A Delete clear coat? Do you've any idea about Delete clear coat?
Offline Rob.K
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
Re: Have question?
« Reply #5 on: February 08, 2014, 07:52:34 PM »
Delete Clear Coat option is mainly for weight reduction and increased fuel economy. Everyone serious about performance does the Clear Coat delete.  ;D
Offline cal320i
  • Trade Count: (0)
  • Newbie
  • Gender: Male
  • 1st gear
    • View Profile
Re: Have question?
« Reply #6 on: February 08, 2014, 07:57:07 PM »
So, how can I do weigh reduction and increased fuel economy? I'm little confuse about Delete clear coat. What kind of performance I can get with it (Delete clear coat)? Can you clarify pls?
Offline Rob.K
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
Re: Have question?
« Reply #7 on: February 08, 2014, 07:57:32 PM »
So after some googling, apparently that is an actual option...
Something to do with delivery and shipping of the vehicle. Not sure what exactly that's for. Maybe someone else on here knows?
Offline Dr. Anthony
  • Anthony Barone
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
    • AlbertaBimmers
  • Vehicle: E92 M3
Re: Have question?
« Reply #8 on: February 08, 2014, 08:22:26 PM »
Crazy!  It basically gives you the frosted color in your paint.  And not a shiney gloss look.
I honestly had no idea this was an option in the e46. I had to google it. Apparently its pretty rare.  Someone special ordered a 320i with that option.
2008 E92 M3
2008 535xi Msport
Offline Rob.K
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
Re: Have question?
« Reply #9 on: February 08, 2014, 08:23:13 PM »
Old school frozen paint! Pretty cool!
Offline Dr. Anthony
  • Anthony Barone
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
    • AlbertaBimmers
  • Vehicle: E92 M3
Re: Have question?
« Reply #10 on: February 08, 2014, 08:24:41 PM »
It kind of makes sense tho.  You would sometimes see an e46 with really dull paint.  I always thought they never took care of the paint.   How has your paint held up over the years? any pics?
ps welcome to the forum!
2008 E92 M3
2008 535xi Msport
Offline cal320i
  • Trade Count: (0)
  • Newbie
  • Gender: Male
  • 1st gear
    • View Profile
Re: Have question?
« Reply #11 on: February 09, 2014, 11:56:19 AM »
Thank you all for comments. Here's pic.
Offline Rob.K
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
Re: Have question?
« Reply #12 on: February 09, 2014, 12:05:24 PM »
^ Looks pretty shiny for no clear coat  ???
Offline cal320i
  • Trade Count: (0)
  • Newbie
  • Gender: Male
  • 1st gear
    • View Profile
Re: Have question?
« Reply #13 on: February 09, 2014, 01:28:46 PM »
Still looks not bad with delete clear coat. I also find this code S8SPA Steuerung COP Control unit COP. What is it mean?
Offline Rob.K
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
Re: Have question?
« Reply #14 on: February 09, 2014, 04:32:47 PM »
COP = Coil on Plug
So each spark plug has a coil instead of a firing control box for all of them.
