Author Topic: N52 BMW Performance Exhaust Installation DIY  (Read 9230 times)
0 Members and 1 Guest are viewing this topic.
Offline Sparkie
  • Trade Count: (0)
  • Jr. Member
  • Gender: Male
  • 69th gear
    • View Profile
« on: February 05, 2014, 08:48:04 PM »
BMW Performance Exhaust DIY
Foreword:
1. I have taken the BMW installation instructions for the PE muffler that was posted to another thread and converted it to PDF, it is attached - I suggest downloading and using this for reference. Attachment here: http://www.e90post.com/forums/attachment.php?attachmentid=850241&d=1366586113
2. If you have access to a hoist, I strongly suggest you use it, it will make this DIY much easier.
3. Get a buddy to help, even if they just hold a light, help lift components into place and collect bolts it will make the install much smoother.
4. If you do not have access to a hoist, I suggest purchasing a large floor jack to assist with jacking the vehicle up high as the more height you have here, the easier it will be.
5. For proper jacking locations, reference this thread:http://www.e90post.com/forums/showthread.php?t=461718%22
6. You may or may not drop the entire exhaust from the headers back, I did not but this DIY assumes you will be removing the exhaust.
7. This DIY is performed on an 09 323i LCI but the procedure will be the same for the 325i & 328i as they use the exact same exhaust. This procedure will be similar to the 330i but will not apply to the 335i
8. This DIY utilizes jacks & jack stands, replace these steps with proper hoisting procedure if you are using a hoist.
9. Be sure to use proper safety procedures when jacking, lifting, cutting, etc. A good Bimmer Enthusiast is a live one.
10. There is a break in period for this exhaust, at first it will sound loud and somewhat 'ricey', but given time it mellows out and becomes deeper and raspier. Full break in time on my vehicle was about a month, however this will likely vary given ambient temperature and how often you drive.
11. I apologize for the dirty car, it's been pretty gross here lately, I have since washed her lol
Step one: Suitably raise and support the vehicle. I find using ramps helps with lifting the front of the vehicle, use em if you've got em!
Step two: Prior to install, go out and purchase a "Exhaust Hanger Removal Tool" AKA "Exhaust Hanger Pliers". These can be purchased from Princess Auto, NAPA, Snap-On, and found online. You do not have to purchase these, but they cost about $10-$15 and will save you literally hours as well as prevent damaged parts. I did not buy one of these at first, spent 3 hours attempting to remove and damaged two hangers, one is shown below, trust me buy this tool. A DIY of how to use it is located here: http://www.youtube.com/watch?v=An1MPa2CwzY Note: If you are having trouble removing the hangers use WD-40 or a dish soap+water mix as lubricant to help with removing the hangers, just spray it in the hole in the hanger where the bracket connects
Step three: If you are dropping the entire exhaust, remove the bolts as shown below
Step four: Support the muffler with a rolling floor jack
Step five: Remove the three exhaust hangers
Step six: Cut the midpipes. Use a saws-all or cutting disk. If using a saws-all purchase titanium coated blades, they will make the job much easier. If you did not remove the original midpipe & secondary cats, you will not be able to use a cutting disk, you must use a saws-all - also take extreme care when cutting to not puncture the heat shield! If you did not drop the exhaust, remove the cut portion of the exhaust once your cuts are finished by sliding it toward the rear of the vehicle, it will just drop out.
Step seven: Remove the Acoustic Distributor and relocate to the PE Muffler
Step eight: Install the PE midpipe & clamps. Note: If you dropped the entire exhaust, re-install the original midpipe with the secondary cats and all other brackets/plates removed in step three prior to installing the PE midpipe.
Step nine: Install the PE muffler
Step ten: Torque the midpipe clamps
Step eleven: Torque the muffler clamp
Step 12: Ensure the exhaust tips are aligned properly and all clamps are secure, adjust as needed
Step 13: Lower the vehicle, put the tools away & start your bimmer!
« Last Edit: February 05, 2014, 10:11:14 PM by Sparkie »
Ian - Aftermarket Electronics Installer "If you haven't burned the skin off your hand, you aint doin it right!"
2009 Jet Black E90
LED AE | AE DRL Mod | BMW Performance Intake + Charcoal Filter delete | BMW Performance Exhaust | AA Stage 2 | M3 Steering Wheel w/ Paddle Shift
Offline rand22
  • Trade Count: (0)
  • Jr. Member
  • Gender: Male
  • 1st gear
    • View Profile
  • Vehicle: e92 335i
Re: N52 BMW Performance Exhaust Installation DIY
« Reply #1 on: February 05, 2014, 09:03:36 PM »
This is so neat.... well done on your post sparkie...
Offline Rob.K
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
  • Vehicle: 2008 135i 6MT
« Reply #2 on: February 05, 2014, 09:04:40 PM »
Very nice DIY!! Very clean
Current - 2008 135i 6MT | JB4 | BMS DCI | CP-E FMIC | ER CP | Meth Addict | BMS DP's
Current - 2008 4.8i X5
Sold   -    2007 335xi AT | JB4 | BMS DCI | CP-E FMIC | ER CP | Meth Addict | AR DP's | Vanguard Exhaust | 12.1@117
Offline rand22
  • Trade Count: (0)
  • Jr. Member
  • Gender: Male
  • 1st gear
    • View Profile
  • Vehicle: e92 335i
« Reply #3 on: February 05, 2014, 09:09:46 PM »
I wish i have that hydraulic lift in my garage!! lol.... thats the first thing that we should all have.. for the ultimate DIY-er.....
Offline Sparkie
  • Trade Count: (0)
  • Jr. Member
  • Gender: Male
  • 69th gear
    • View Profile
« Reply #4 on: February 05, 2014, 09:16:45 PM »
^^ agreed. I want to build my dream house one day with a 4 bay garage and a hoist in it.
Unfortunately you would probably need to re-enforce the garage slab to do this in a residential home which is already built :(
And thanks for the kind words on the DIY, BMW PE is an amazing sound, highly recommended!
It also keeps sounding better and better and better as time goes on. I've had mine for about a year and it just wont stop! Every time I hear it it sounds better. Love BMW's engineers haha.
Sound clip: http://instagram.com/p/ciyJ8xjIIS/
« Last Edit: February 05, 2014, 09:42:16 PM by Sparkie »
2009 Jet Black E90
Offline Dr. Anthony
  • Anthony Barone
  • Global Moderator
  • Trade Count: (0)
  • Full Member
  • Gender: Male
    • View Profile
    • AlbertaBimmers
  • Vehicle: E92 M3
« Reply #5 on: February 05, 2014, 09:49:41 PM »
Such a beautiful write up.  Awesome work ian!
2008 E92 M3
2008 535xi Msport
Offline Sparkie
  • Trade Count: (0)
  • Jr. Member
  • Gender: Male
  • 69th gear
    • View Profile
« Reply #6 on: February 05, 2014, 09:52:03 PM »
Thanks Anthony!
Hoping there is someone here who will take the plunge and use it :)
2009 Jet Black E90
Offline SOL403
  • Trade Count: (0)
  • Newbie
  • Gender: Male
  • 1st gear
    • View Profile
  • Vehicle: 2006 330xi
« Reply #7 on: February 12, 2014, 05:26:49 PM »
Nice DIY, thanks for sharing!
Mtec AE - Blacklines - LED interior - ACS style front lip/roof spoiler/pedals - CF grill/trunklip/plate frame/badges - 19" VMR V701 - Michelin PS2 - Res delete - Eisenmann Race Exhaust- Simota V2 intake - Cyba airscoops - KW V1 coilovers - BMS PBX - Stoptech rotors/pads - Mtech rear - Wrapped
Offline AWD403
  • Trade Count: (0)
  • Newbie
  • Gender: Male
  • 1st gear
    • View Profile
  • Vehicle: 07 335xi
« Reply #8 on: February 12, 2014, 09:17:22 PM »
excellent!!!
2007 335xi, Custom Stage 3 Tune, JB4, VRSF Downpipe, STETT Cold Air Intake, VRSF 7" Intercooler, Eibach Pro Kit, Vanguard, Race Gas...blah...blah...blah, let's do this!
